In your threaded rendering approach how do you finally draw the result. The original paint event that triggered the threads is over and you can't draw to a widget outside of a paint event. Do you use a timer to fire a paint event and then use the computed result?
Yes, basically that is the way it is done.
The basic class implementing that in KLayout is
lay::LayoutCanvas(layLayoutCanvas.cc) inLayoutCanvas::update_image. This class connects to the drawing threads through asynchronous callbacks (signal_transfer_done,signal_end_of_drawing)."Asynchronous" means they can be called from any thread. They will be dispatched into the main thread by a mechanism called
deferred executionin KLayout's source (tl::DeferredExecutionobject). That is nothing else than a Qt timer which is used to delegate the execution of a method to the main thread. Today there is "Qt::QueuedConnection" mode which to my understanding works the same way, but wasn't there when KLayout was initiated.If you want to look further, the actual drawing happens inside a thread that is implemented in
layRedrawThreadWorker.ccandlayRedrawThread.cc(the names are slighly confusing asRedrawThreadis actually a thread group whileRedrawThreadWorkeris one of the multiple drawing threads).RedrawThreadWorkerregularly callestest_snapshotwhich itself callswakeupfromRedrawThreadafter having stashed the current bitmaps for image composition. The latter will triggersignal_transfer_doneand this is the call that is delegated into the main thread and updates the screen image from the bitmaps.Hope that helps,
