Hi Matthias-
I have a layout with weird shaped via polygons that I'm trying to get a more smooth shape for the 2.5d to draw.
Below is an example. There is external notch on top and internal notch in the bottom:
Is there a DRC expression that can make such polygon to be an ellipse shape as it physically show after photo\litho?
No, that would be a lithography simulator. They usually work by digitizing the shape into a grayscale image and applying a transfer function kernel (essentially a low pass filter) before turning the image back into a resist contour.
DRC is not meant for these type of manipulations.
