Hello Matthias,
In my environment below, I got a timeout (after 60 sec) while fetching http://sami.klayout.org/repository.xml.
OS: Linux Mint 20.3 (5.4.0-166-generic)
g++: version (Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0
KLayout: 0.28.12 source code build
  * Q5: 5.12.8
  * Ruby: 3.1.3
  * Python: 3.8.10
  * built with:
      ./build.sh  \
           -release \
           -qmake         /opt/Qt5/bin/qmake \
           -ruby          /usr/local/bin/ruby31 \
           -python        /usr/bin/python3 \
           -build         ./qt5.build.linux-64-gcc-release \
           -bin           ./qt5.bin.linux-64-gcc-release/ \
           -option        -j8 \
           -with-qtbinding \
           -qt5 \
           -rblib         /usr/local/lib/libruby.so.3.1 \
           -rbinc         /usr/local/include/ruby-3.1.0 \
           -rbinc2        /usr/local/include/ruby-3.1.0/x86_64-linux \
           -pylib         /usr/lib/x86_64-linux-gnu/libpython3.8.so.1.0 \
           -pyinc         /usr/include/python3.8  2>&1 \
          | tee           qt5.build.linux-64-gcc-release.log
Both curl http://sami.klayout.org/repository.xml (with proxy settings in $HOME/.curlrc) and wget http://sami.klayout.org/repository.xml (with proxy settings in $HOME/.wgetrc) work fine (took about one second) in a terminal.
I have libcurl.so.4.6.0 installed, but it does not seem to be used.
Instead, libQt5Network.so.5 seems to be linked.
What am I missing?
Thanks and best regards,
Kazzz-S
Hi @sekigawa,
I think QtNetwork does not recognize the proxy settings from
.curlrcor.wgetrc. I understand that Qt uses the "system proxy" by default and I do not configure anything else. Honestly, I never had to configure proxy settings myself. Even in a company network, QtNetwork worked without changes.I found a little documentation here: https://doc.qt.io/qt-5/qnetworkproxyfactory.html#systemProxyForQuery. I don't know if that helps.
If the solution is curl, you can try using libcurl by building with "-libcurl" in build.sh. That enables libcurl instead of QtNetwork. My understanding is that after this, KLayout should respect ".curlrc", but I have not tested that myself.
Hi @Matthias,
Thanks for the URL, which was helpful.
It says:
In my launching service Bash script, I set
export http_proxy=http://111.222.333.444:5678.Then, fetching was successful.
Warm regards,
Kazzz-S
Next, in relation to No.2399, using the same Linux environment:
Direct Internet connection from Mac
The unit test
tlGitTestspassed in the four environments.Very good
 ! Thanks for sharing this information!
Connection from Linux via Proxy
I'm playing with
libgit2I have found a way to solve the timeout problem in the Linux environment with the following changes.
I'm sure there must be a more sophisticated way to handle a proxy.
But just for information.
Hello @sekigawa,
thanks for sharing this code piece.
I'm sorry I missed that ... I am right now releasing 0.28.13 (for now without that patch). But I am sure there will be an update soon.
I just wonder whether it is not possible to configure a proxy in general through the system. I was somehow assuming libgit2 would be using curl and that curl would read "http_proxy" itself without need to configure it externally. But looks like I am wrong. I still feel it is a bit weird that proxies need to be configured in the code.
Hello @Matthias,
I agree. Please take your time.
Warm regards,
Kazzz-S
Meanwhile, in the
mingw64environment, I got an error when startingut_runner.exe, as shown below.What could be the reasons?
All test modules seem to be there...
Thank you.
Kazzz-S
Hi Kazzz,
Is $LD_LIBRARY_PATH actually working? To be frank I have not tried myself - I though there is not such thing on MSYS ..
Let me share with you my complete configuration to run the test suite on my Jenkins instance. Maybe this helps. I assume the interesting part is the comment about Python >= 3.8:
Hi @Matthias,
Regarding LD_LIBRARY_PATH, your point is correct.
Kazzz-S
Hi @Matthias,
Thank you for sharing the code
  I could run
ut_runner.exeusing the attached script in my mingw64 environment.In my company's Windows environment, the proxy to be used is automatically assigned according to each PC's IP address, so setting the http_proxy environment variable is unnecessary. But the above changes in
tlGit.ccare required.<== My misunderstandings. Both are required.
Kazzz-S
Hi @sekigawa,
I picked up your suggestion about the HTTP_PROXY variable, but I found it may interfere with curl's own mechanism when built against curl.
I decided to call the variable "KLAYOUT_GIT_HTTP_PROXY", so it is unique. I tested the implementation with squid and it seems to work. I will release that feature with the next minor release.
Hi @Matthias,
Thank you for supporting the proxy. I like your idea.
I'll set the
KLAYOUT_GIT_HTTP_PROXYenvironment variable in my launching service Bash script.Best regards,
Kazzz-S
