Hello sirs,
Not sure any hardware or software restriction to launch 0.29.0 version ?
version 0.28.13 works fine in my laptop, but latest one give no response, they are all (64bit binaries)
Vincent
No, there are no specific restrictions.
0.29.0 uses a different Qt version and there might be interactions with other versions.
I assume you run Windows. I have tested the installation on different Windows 10 machines without trouble.
There may also be interactions with installed scripts or binary extensions, although I take care that things are backward compatible.
You can try the following things:
- uninstall before installing 0.29.0
- remove or rename the KLayout configuration folder in C:/users/your account/KLayout to disable existing packages and configurations
- check if you maybe have a parallel installation by searching for klayout_app.exe system wide. This may happen if you have installed one version as admin and the other as user.
Let me know your findings.
Thanks for the new major release 0.29.0
Release work is always hard :-(
On Windows 10, I usually install the *.zip package, and I am facing the same problem.
Before unpacking the ZIP, I completely delete previous binaries.
I noticed the
pymod/directory is missing whereklayout_app.exeexists.This means the
klayoutpackage is not included in the binary package (at least in the ZIP package).I believe this is the root cause of the problem.
As we discussed previously offline, a MacOS binary (>= 0.29.0) would also not launch without
pymod/adequately deployed.On the other hand, I could successfully build, deploy, and launch 0.29.0 from the source in my MinGW64 environment.
My home-made ZIP includes the
pymod/directory.I deeply copied the
pymod/directory into the ZIP-unpacked directory.Then the program started normally.
The
klayout-0.29.0-win64-install.exeinstaller is OK.Regards,
Kazzz-S
P.S.
The build work for MacOS is going as usual.
Hello Kazz - San & Matthias
Thanks for sharing, I followed the hints from Matthias to solve this, but I was not lucky.
I have deleted all versions of binaries, and downloaded install-type for today's homework
it's great to know that install-type is ok to run in advance. But one thing strange, I find no
< pymod > folder in my so far 0.28 version and it works properly.
I still like zip type more than install one
  I will update if something worth
Thanks for all help
Vincent
Hi Vincent,
The need for the < pymod > folder is one of the major changes in version 0.29.x.
That's why.
Kazzz-S
You are right. Thanks for the debugging and the hint about the .zip file. I was only thinking of the installer exe.
The strange thing is that also cert.pem is missing and both pymod and cert.pem are included in the build scripts. It looks like a problem of the script I use for code signing.
I will debug that and regenerate the .zip files.
If you need the .zip file quickly, you can take the one from http://www.klayout.org/downloads/master. These are unsigned however, but have pymod and cert.pem.
Thanks again and best regards,
Hi Vincent,
The changelog says:
Even though I think Matthias will soon update the binaries, I attached a ZIP file containing the
pymodI built for Windows 64 (MinGW64).Regards,
Kazzz-S
Hi Vincent,
The timing of my post conflicted with Matthias'.
Follow his instructions.
Kazzz-S
Hello gentlemans
Sure, thanks for pymod material, and look forward to new zip.
Vincent
@sekigawa and @Vincent Lin,
many thanks for your patience and many thanks for getting me to the point. I've added testing the .zip files to my release test procedure checklist.
I have updated the .zip files. No new release is needed - it was the repackaging after code signing that went wrong. I still used the scripts for 0.28 which die not have pymod. I also did not include cert.pem which explains some other issue on GitHub. I can now download the .zip, unpack and run KLayout directly from the folder.
I really appreciate this community effort!
Thanks a lot!
