Hi sir ,
as below , I want to change a GDS layer number from X to 500+X.
after running this script  , that is not workable.
Could you please help to check it if any problem in the code?
Thanks.
mw.layout
view = mw.current_view
layer_list= Array.new()
view = RBA::LayoutView::current
li = view.begin_layers
while !li.at_end?
lp = li.current
#puts "#{lp.source_layer} #{lp.source_datatype}"
lp.source_layer=lp.source_layer+500
li.next
Hi @jiunnweiyeh,
This script changes what layer are displayed, not the layers themselves.
So you need to change both the layer number of the layer displayed and the layer number in the database:
Disclaimer: this does not work if you have the same layer displayed multiple times and will only change the layers in the layer list.
