Hello. i'm a beginner
I would like to know the following two things
how to convert gds to dxf through a script
(I Know this is a duplicate question but, i want to know a brief example)
how to set convert options
(gds layerNumber → dxf layerName, Color)
I really need help..
1. how to convert gds to dxf through a script
See, for example, https://www.klayout.de/forum/discussion/2514.
The attached ZIP file contains modified versions of Python scripts for the above post.
The scripts assume that a CAD tool interprets the coordinates in the DXF as millimeters.
Try
2. how to set convert options
The DXF writer does not provide many optional parameters, as shown in the figure below.
The most important one would be
dxf_polygon_mode.As far as I know, the KLayout's DXF writer does not provide explicit layer naming and color mapping today.
The layer name will be
L{xxx}D{yyy}, where {xxx} is the layer number and {yyy} is the datatype number in the GDS, respectively.So you can use a text editor to find the layer names and replace them if necessary.
Similarly, colors in DXF are automatically mapped to AutoCAD color indexes.
To set/change colors, use a DXF CAD tool, not KLayout.
I've done a little research on colors by dumping and filtering the `ringo.gds' file.
As you can see in the image above, the first layer is L/D=5/0, which is given
index=1.The second L/D=1001/0 is mapped to
index=2. The third L/D=8/0 is mapped toindex=3, and so on.The DXF color indexes on the left (12, 5, 8, 7, ...) were found by manually searching the DXF file.
According to the table below, index = (1,2,3) corresponds to color = (red, yellow, green), which corresponds to the middle part (QCad screenshot) of the image above.
Cont.
3. Loading a DXF file
In contrast, the
LoadLayoutOptionsclass provides many options for reading DXF files.The attached ZIP file contains the
f2543-rev.pyscript, which reverse convertsringo-fruits.dxftoringo-fruits.oas, where layer mapping is performed on the fly.However, changing/setting the layer colors has to be done manually. Or write (add) code to automatically generate the
*.lypXML file.
