I'm wondering if there is any helper function/method that allows me to retrieve the absolute position of a shape (relative to the top level cell) in a hierarchical GDS  - or do I need to walk my way back to the top cell through the instance tree ?
The use case is to retrieve the position of shapes on a particular layer that defines the bonding pad openings  in a ASIC.
I'm using a code similar to this:
def get_bbox_for_cells_containing_cb_layer(
    layout: kdb.Layout, layer: int, datatype: int
    layer1 = layout.layer(layer, datatype)
    top_cell = layout.top_cell()
    iter = top_cell.begin_shapes_rec(layer1)
    while not (iter.at_end()):
        if iter.shape().is_polygon():
            logging.debug("Polygon: " + str(iter.shape().dpolygon))
            logging.debug("  From shape " + str(iter.shape()))
            logging.debug("  Property   " + str(iter.shape().properties()))
            logging.debug("    BBOX " + str(iter.shape().dbbox()))
        elif iter.shape().is_path():
The shapes I'm collecting are "deep" into the hierarchy of the GDS (they don't belong to the top level).
Thank you
About this?
Test Data
Code and Results
With two instances of cell
AUpdated: 2024-09-17
