I have switched computers and needed to download Klayout again. This went smoothly for version 0.30.12. Next I have attempted to install the Ruby based xsection script 1.10. This results in "Error downloading Git repo from https://codeberg.org/klayoutmatthias/xsection.git (subdir 'src',ref")" What am I doing wrong?
As explained in
README.md, we do not need to touch the raw git repository (https://codeberg.org/klayoutmatthias/xsection.git) if we simply use the package.Installation step
Sample run
When running a
.xsscript for the first time, select "Run Script" and choose the.xsfile.The recent scripts are stored in
$HOME/.klayout-xsection.We need to clone the repository to run tests and generate HTML documents.
Run tests
Generate HTML documents
I have followed your instruction previously and again after following your instructions.
Seems quite simple but doesn't work. I have been using the cross-section tool for many years and have a number of Ruby process flows generated and don't want to lose that work.
I have downloaded the www.klayout.org 1.0 - Ruby scripts with no problems using this approach.
I was able to copy the salt directory from my old computer and place it in the KLayout folder on the new computer. I can now run xsection. At least the 1.4 version.
OK, then try the following steps as a workaround.
macOS / Linux terminal with
gitWindows-11
cmd.exewithgit.exe
