It seems that the Orientation and Text size functions in Object Properties window didn't work.
I tried to modify these two functions in editor mode and apply the change, however nothing happened in the main window, could you please help to confirm it?
My environment: klayout v0.19.2 on MDK 9.2 amd64 with qt4 v4.3.1
Is it possible to add an info to display the [current number/total selected] in Object Properties window if selected more than two objects?
For example: If two objects are selected, when the properties window is opened, it shows [1/2], after pressed Next button, it switchs to next object and shows [2/2].
Best Regards,
chi-hsiang-hung
In order to make the text objects show up in the given orientation and size you need to select a vector font and check the "Apply text scaling and orientation" check box on the "Display" page in the "Setup" dialog. By default, text objects show up in a fixed orientation and size. That is probably why you don't see any effect.
Yes, I followed the steps to change the display font from Default to others(Sans serif or Gothic) in Setup window, and the text modified to the one I specified.
Another issue which is not so important, when we select several text objects and try to change the properties, is there a function like "apply modified to all selected"? so we can change the Text Size and Orientation at one time and would not effect the Text and Position.
Best Regards,
chi-hsiang-hung
applying one change to multiple objects in the selection is not straightforward unfortunately for internal reasons. That is something to go into some "search & replace" functionality.
For your use case however as usual there is a script to do this:
This sample resets the text orientation to r0 and the text size to 1 micron. For demonstration, this script also adds a "*" to the string. For the actual application, this script should be adjusted accordingly.
I tried to run this code with some modification, and the program is crashed on the line "lv.cellview(sel.cv_index).cell.shapes(sel.layer).replace(sel.shape, text)", even I almost remark all the lines.
The error message is "Segmentation fault", and I have no idea how to fix it, could you please give me a hint to solve this issue?
The test platform is klayout v0.19.2, ruby 1.8.6
BTW, is it possible to popup an interactive window that we could input the orientation/size/text in it and apply the input value in the change_texts code?
maybe it would be better for operation.
Best Regards,
chi-hsiang-hung
the segmentation fault was probably a bug: when a text was selected in a child cell, the script did not work properly. I changed the code above accordingly.
Currently there is not a good method to provide user interfaces with ruby scripts. Therefore this script does not provide a dialog right now.
