Full layout BBox
I have a script that I used for long to draw a box all surrounding the full layout of the active cell.
But something is now wrong and I cannot figure out why cv.layout.is_valid_layer?(li) never pass.
Please, can you help to find the missing instruction to insert the boundary_box ?
Thanks, BRgds,
# $description: BBox of the current cell L
# $autorun
# $show-in-menu
# $menu-path: tools_menu.end
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
# DESCRIPTION: Compute and output the bounding box of a cell (all layers)
# Run the script with
#   klayout -rm cell_bbox.rbm ...
# or put the script as "cell_bbox.rbm" into the installation path (on Unix for version <=0.21:
  mw = app.main_window
  view = mw.current_view
  cv = view.active_cellview
  if !cv.is_valid?
    return
  cell = cv.cell
  dbu = cv.layout.dbu
  # implement undo
  view.transaction("Boundary")
  sel_layers = view.selected_layers
    if !sel_layers || sel_layers.size == 1
      sel_layers.each do |lp|
      li = lp.current.layer_index
      print("layer : #{li.to_s} :  #{cv.layout.get_info(li).to_s}  :  #{lp.current.name}\n")
        if cv.layout.is_valid_layer?(li)
        boundary_box = RBA::Box::new(cell.bbox.p1, cell.bbox.p2)
          cell.shapes(li).insert(boundary_box)
          print("BBox drawn")
  text = "Cell: #{cv.layout.cell_name(cv.cell_index)}\n\n"
  text += "xmin: #{cell.bbox.left*dbu} micron\n"
  text += "ymin: #{cell.bbox.bottom*dbu} micron\n"
  text += "xmax: #{cell.bbox.right*dbu} micron\n"
  text += "ymax: #{cell.bbox.top*dbu} micron\n\n"
  text += "width: #{cell.bbox.width*dbu} micron\n"
  text += "height: #{cell.bbox.height*dbu} micron\n\n"
  text += "surface: #{cell.bbox.width*dbu*cell.bbox.height*dbu/1000000} mm2"
  RBA::MessageBox::info("Cell Information", text, RBA::MessageBox::b_ok)
  view.add_missing_layers
  view.commit
  view.update_content
  view.zoom_fit
  • edited September 13
    Hi Laurent,
    I tried the script with 0.30.12 and it seems to work. I can select a layer and after running the script it will paste a box with the layout's dimension on that layer. Even undo works.
    However there is a catch: when the selected layer does not exist yet - i.e. it is in the layer list, but not in the database, then this script will not work. This often happens when you use a layer properties file. It may contain layers that are not existing in the database. So either you create the target layer first, using "Edit/Layer/New Layer" or you modify the script to make sure the layer is created:
      if sel_layers.size == 1
        lp = sel_layers[0].current
        l = lp.source_layer
        dt = lp.source_datatype
        if l >= 0 && dt >= 0
          # NOTE: this creates the layer if it does not exist yet
          li = cv.layout.layer(l, dt)
          cell.shapes(li).insert(cell.bbox)
          print("BBox drawn")
